Another X-Pipe Question
Old Oct 30, 2002 | 04:34 AM
OfficerZ28's Avatar
Default Another X-Pipe Question
I know there are lots of x-pipe questions out there, but decided to post my own.
Can i install an X-Pipe with the Loudmouth?
When you guys install your x-pipes, what type of setups are you doing? Bullets, thunder chambers...etc?
Do you have to extend the piping over the axle to make dual tips? How does an x-pipe work?
Will it be comparible to the Loudmouth?
Where do i get an x-pipe?
any input with be appreciated... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Oct 30, 2002 | 05:17 AM
DARK AGE 53's Avatar
Default Re: Another X-Pipe Question
Check with Justin Sutton wheather his x pipe will work for you.
Al
Old Oct 30, 2002 | 08:06 AM
Silver99Z's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by OfficerZ28:
<strong>I know there are lots of x-pipe questions out there, but decided to post my own.
*** No. The xpipe has two inlets and two outlets. Loudmouth works with the one outlet from a ypipe.
*** Mufflers of your choice or no muffler at all.
*** You can dump under the car or out the sides. I have seen a pic where a guy ran two 2.5" pipes over the axle on pasenger side. Mine goes under the axle. It's your choice.
*** You can read all about the Xpipe at http://drgas.com - Type this in from your browser and it should work.
*** Depending on what muffler you use, it could be as loud or quieter.
*** The actual X piece can be bought from DrGas or can be made by a good muffler mechanic, but the rest of the piping will have to be custom fabricated.
any input with be appreciated... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
<small>[ October 30, 2002, 08:17 AM: Message edited by: Silver99Z ]</small>
Old Oct 30, 2002 | 07:49 PM
justin sutton's Avatar
Most people are running bullets,borlas,dynomax's etc.You can still run duals over the axle with a xpipe.With the xpipe you run true duals from your manifolds or headers to the x then to you mufflers and turn it down in front of your rearend but you can go over your rearend out the back.Its just however you want to do it.I hope this helps.
