EGR question
Old Oct 30, 2002 | 10:16 PM
Silver99Z's Avatar
Default EGR question
Help a dummy here.
Does EGR function all of the time? If so, seems to me that dumping hot exhaust air into the intake is diametrically opposed to keeping intake air cold as far as hp is concerned. Anyone have an idea how much hp might be gained by eliminating EGR?
Old Oct 30, 2002 | 11:32 PM
RTCamaroSS's Avatar
Default Re: EGR question
No, the EGR does not fuction all the time (ie. constantly dumping exhaust in the intake)... I dont know the specifics on exactly when the EGR dumps. I know the AIR usually only works on startup and until the car is warmed up, then it clicks off... dunno bout the EGR though.
Old Oct 31, 2002 | 01:13 AM
ZYouL8R's Avatar
I'm pretty sure the EGR functions at all times for emissions purposes.
Old Oct 31, 2002 | 01:17 PM
felton316's Avatar
In Ls1 edit it has a place where you can change the EGR to enable and disable. It shows my 98 enables EGR after VSS signal goes above 44 and diables when it slows down to 42.
Old Oct 31, 2002 | 04:51 PM
Cody Brooks's Avatar
the egr doesn't work at full throttle or idle and it helps keep the engine slightly cooler by reducing the amount of heat produced in the cylinders.
