Where does this vacuum line go?
Old Nov 2, 2002 | 11:17 AM
BB's Avatar
BB
Default Where does this vacuum line go?
On a 2000 LS1 TA M6. There is a vacuum line that comes out of the wiring harness just below the clutch resevoir, just below and in front of the brake booster. It is a little bit bigger than the vacuum lines to the intake - won't reach the intake anyway.
Can someone look and see where this goes?
Thanks.
Old Nov 2, 2002 | 11:20 AM
BB's Avatar
BB
Default Re: Where does this vacuum line go?
If it is for the AIR shut off valved mine has been removed. Do you plug this vacuum line then?
Old Nov 2, 2002 | 05:00 PM
WILWAXU's Avatar
The one for the air system attaches to the a small ?solinoid? that apprears to be a part of the injector harness... your not talking about the brake booster line are you?
<small>[ November 02, 2002, 05:09 PM: Message edited by: WILWAXU ]</small>
Old Nov 2, 2002 | 09:17 PM
BB's Avatar
BB
No it is not the large booster hose. I had a friend bring his TA over and it is the washer hose! I must have pulled it during the master cylinder swap.
