PCV Valve?
Old Nov 3, 2002 | 08:52 PM
99FireTA's Avatar
Default PCV Valve?
Okay, this is probably a dumb *** question, and maybe I'm blind... but where the hell is the PCV valve on our cars??? We do have one right?? I did an oil change and figured I'd change that as well, I took off the tower brace and FRC's but don't see the valve!! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 3, 2002 | 09:28 PM
Farmer2's Avatar
Default Re: PCV Valve?
I have a 2000 WS6 and mine is about 2 in away from the bottom passenger sides throttle body base.
It is under a thin coated rubber hose, just peel it back and wala there it is.
Old Nov 4, 2002 | 05:11 PM
99FireTA's Avatar
Thanks farmer... I'll check it out tomorrow <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Nov 6, 2002 | 12:26 AM
James1's Avatar
Will getting a new PCV valve fix my oil consumption problem? I have a 00 LS1
Old Nov 7, 2002 | 09:22 AM
funeclown's Avatar
My consumption seems to be a little less with the new GM PCV Valve part #12572717
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> It has a pinhole instead of the checkvalve typ construction. Good Luck!
Old Nov 8, 2002 | 12:05 AM
rnr27band1's Avatar
install university has a whole write up on how to change the pcv valve.
