New guy to LS1Tech needs help! Please help!
Thanks,
Sam
Anyways now to the real question, visually you can not pass an emmisions test, because you cat has been moved. BUT you can pass the tecnical test where they stick that stupid thing in your exhaust. So my advice is to buy a set of car sound or random tech cats. I read somewhere that Random Techs flow a little better. Just have a shop weld in the cats into the Y.
Also there are some other things you need too, so you don't throw any codes(SES Lights) or something like that.
Lastly, I believe for Hookers, you should have your car tuned for maximum performance.
<strong>Check some of the sponsors, Dont put the stock cats on, because you would go from a 3inch collector to a 2.5inch cat, that would kill your hp, just get some high flow cats on a mufflex Ypipe, they are really good! thats just my opinion.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">accually the stock cat is a 2 1/4 inch cat.
get a cat-shell and run straight pipe through it to pass visual test for a convertor i don't think the authorities will know where the factory cat was. ls1's can pass emissions tests in all states except california without cats or so i've been told. find someone with an emissions testor and see if it will pass without cats before hand to be safe though. perhaps you'll only have to get 1 cat and then have a dummy cat on the other side. regardless you should get o2 simms to keep the codes from being thrown.
<small>[ November 05, 2002, 09:02 PM: Message edited by: LOnSLO ]</small>
Same cat, but now 3" in and out, for "free"! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ November 06, 2002, 10:44 AM: Message edited by: SS_Steve ]</small>
