Y pipe
Old Nov 6, 2002 | 10:07 PM
Archdog7564's Avatar
Default Y pipe
I was wondering about replacing my stock Y pipe. i think my options are an off road pipe or a y pipe with high flow cats... my car is lowered an 1.25", and i have hooker shorties... my questions are ground clearence, smell and install, i can;t install the off road pipe by myself, so any advice,,, i want alittle power gain,,, thanks for all your help
justin
Old Nov 7, 2002 | 03:54 PM
Default Re: Y pipe
any advice...
thanks for your help
justin
Old Nov 7, 2002 | 07:40 PM
Cody Brooks's Avatar
Default Re: Y pipe
remove your cats. makes the car sound mean as heck.
Old Nov 7, 2002 | 09:14 PM
01Z0H6's Avatar
Default Re: Y pipe
Justin, i don't have headers but i do have the LGM Y pipe & Borla. Sounds great! Can only imagine how this would sound with headers.
A much noticed "hollow growl" & noticable power as well. My .02 FWIW.
Old Nov 7, 2002 | 11:29 PM
Default Re: Y pipe
thanks for your advice, but what about the smell and ground clearance? still to my first post, thanks for all your help
justin
Old Nov 7, 2002 | 11:37 PM
SSDude's Avatar
Default Re: Y pipe
Some peope claim a 10hp gain from adding a Y pipe. I cannot verify this. I have not added a Y pipe yet.
Old Nov 8, 2002 | 01:09 AM
02smknSS's Avatar
Default Re: Y pipe
the high flow cats give it some more kick for sure. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I have random cats and i like them alot. I think that as long as you don't have lontube headers, you should be fine. Then again with LT headers you could be fine, i dont know realy. As far aas the smell... New exhaust parts like headers and catbacks will smell until you do a complete cycle of heating them up and cooling them down a few times to let the coating heat properly, and cool down. So if you do ge the cats, dont go crazy right away. take her out slow.
<small>[ November 08, 2002, 01:14 AM: Message edited by: 02smknSS ]</small>
Old Nov 8, 2002 | 01:15 PM
Default Re: Y pipe
justin
 Michael S. Palmer
Old Nov 8, 2002 | 01:57 PM
SSLink's Avatar
Default Re: Y pipe
I, too have Hooker shorties and I run a Bassani y-pipe with cats. The rest of my setup and results below.
Is your car a 2000 or newer? If so you could probably just get something like the SLP or G2 y-pipes which just clamp or weld up behind your stock cats. The '98 and '99 f-bodies had a more restrictive downpipe and cat on the passenger side
which complete, manifold-back y's like the Bassani, Random Tech and Mac will replace.
I like my exhaust setup a lot. Deep, throaty tone without any of the loud resonance or rasp of longtubes. Good off-idle torque due to the 1 5/8" primaries on the Hooker shorties. No ground clearance issues.
I did not dyno the impact of my y-pipe alone but I did feel a SOP benefit at higher RPM's. I can tell you, though, that the Bassani piece, though high quality stainless, was a PIA to install. It took a lot of bending and shimming to keep the collector clear of the driveshaft. Not sure they got the design exactly right. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
<small>[ November 08, 2002, 02:02 PM: Message edited by: SSLink ]</small>
Old Nov 8, 2002 | 06:09 PM
Default Re: Y pipe
i own a 98 Z28
how would i go about to get an off road y pipe on?
justin
