Do you have to change plugs?
Old Nov 8, 2002 | 04:29 AM
ZR2877's Avatar
Default Do you have to change plugs?
Do you have to change plugs after you use Gm top end cleaner. I know changing oil and filter is a must but what about the plugs. Does it affect them. Will it hurt to run car without plug change after running Gm cleaner through it.
Old Nov 9, 2002 | 02:48 AM
ZR2877's Avatar
Default Re: Do you have to change plugs?
ttt
Old Nov 9, 2002 | 04:38 AM
CAT3's Avatar
Restricted User
For peak performance yes, all the build up gets burnt out at start up and can lead to plugs fouling. Good tip if you have high end plugs, like iridium, throw cheapies in to burn out the sh*t then put the good plugs in after a few miles. Save the cheap/old plugs for the next time. Good-luck.
Charlie.
