TB question(easy one)
Old May 1, 2006 | 08:35 AM
bigti99a's Avatar
Question TB question(easy one)
i picked up a throttle body that was on a 2001ss. before i make a mistake and send it out for porting i want to be 100% certain there will be no problems just switching the sensors over from my stocker and putting it on with a new gasket. i have an 00.
Old May 1, 2006 | 08:59 AM
brad8266's Avatar
Shouldnt be any problems.
Old May 1, 2006 | 09:06 AM
FstBlkz28's Avatar
Notta problem at all.
Old May 1, 2006 | 11:10 AM
daryl2cb@yahoo.com's Avatar
same thing, no issues
Old May 1, 2006 | 12:52 PM
bigti99a's Avatar
thanks guys.
Old May 1, 2006 | 12:56 PM
TheBlurLS1's Avatar
That's what she said...
You don't even need a new gasket.
Make sure you get the IAC plunger's o-ring when you pull it out (top of throttle body, driverside) and install it in the new one. My car had a bit of idle surging when I swapped to a ported one, traced it back to that o-ring being MIA.
Old May 1, 2006 | 06:48 PM
bigti99a's Avatar
Default follow up question
are there and if so what are the torque specs for the TB. and is there any trick i should know to get the old one off and new one on? thanks again for any help.
Old May 1, 2006 | 08:59 PM
bigti99a's Avatar
ttt, looking for a little input, thanks.
Old May 1, 2006 | 09:09 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Make sure that the throttle blade assembly will work if you have an early model.
Old May 1, 2006 | 09:13 PM
STRETCH'S T/A's Avatar
when taking old one off you have to remove everything up to the tb, then unplug the sensors, and hoses to get at the 3 bolts to get it off. when intsalling the new tb, just tighten the bolts til they no longer turn, don't overtighten them or you could damage the intake.
Old May 1, 2006 | 09:31 PM
bigti99a's Avatar
thanks stretch
Old May 1, 2006 | 11:43 PM
Luna's Avatar
Originally Posted by everclear4520
post junky
You're cruising for a banning
Old May 1, 2006 | 11:44 PM
Drew's TA's Avatar
No kidding, every post he has made has been "post junky".....
Old May 2, 2006 | 12:49 AM
TheBlurLS1's Avatar
He's on trail in the admin lounge as we speak.
Old May 2, 2006 | 12:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I was sick of it...
Old May 2, 2006 | 07:27 AM
bigti99a's Avatar
did i miss something?????
Old May 2, 2006 | 07:48 AM
GuitsBoy's Avatar
Like orange said, make sure the TB shaft cam is the same size. The 98-99, and possibly early 00's had a smaller cam so youll have too much throttle cable.
Old May 2, 2006 | 07:51 AM
bigti99a's Avatar
is it obvious enough to see with the eye?
Old May 2, 2006 | 07:55 AM
GuitsBoy's Avatar
Yes, should be immediately noticeable side by side.
Old May 2, 2006 | 08:18 AM
bigti99a's Avatar
pardon my ignorance but the shaft cam is the little half moon on the side of the TB right?
