exhaust tips
Old May 2, 2006 | 04:11 PM
83TA02's Avatar
Default exhaust tips
About 3 years ago i put the SLP loudmouth system on my car and ever since then i have left the dual dual tips on there. I just order some megs dual dual tips that have a 3.5 inch outlet and 3 inch inlet, My problem is i cant get these old tips off worth anything, I can get the clamp off but the tips wont budge, they are not welded. can anyone help me with these. Also, my left exhaust tips is starting to sag. I can pull it back into the position but once i hit a bump, it sags again. How can i fix this. Thanks. I drive a 2002 Ws6. My website is also www.cardomain.com/id/83transam02
Old May 2, 2006 | 04:42 PM
conan's Avatar
Try taking a grinder with a cutting wheel and cut a strip parallel with the outlet pipe. Just go deep enough to cut the tip so it will releave the pressure holding it on. You could also try heating the tip up with a tourch to swell the tip off. Were the clamps holding the tips the "U" type??
Old May 2, 2006 | 05:01 PM
83TA02's Avatar
they are circular, they didnt come with the kit when i got it, i really wish not to cut anything just wondering how i can get the dang things off, can a muffler shop do it?
Old May 2, 2006 | 08:23 PM
carado1984's Avatar
almost any garage has an air chisel.. that will do the trick and they will probably charge you for labor.. im guessing itll take a few minutes meaning a few dollars
Old May 3, 2006 | 07:46 AM
83TA02's Avatar
anymore ideas?
Old May 5, 2006 | 11:01 PM
83TA02's Avatar
Back to the top. Anyone know how to muscle tips off or any technique.
