Under the axle?
Old May 2, 2006 | 10:33 PM
SS4Luck's Avatar
Default Under the axle?
I just bought lt's and the tsp true duals, but im in califonira and cant have them dump before the axle... i dont really have the cash to have the exhaust place bund me pipes to go up and over so i was just going to have the run it under... anyone done this? Do's or Dont's on this would be greatly appreciated...
Old May 2, 2006 | 11:19 PM
01bird58's Avatar
Yes, a few on here have done it and I plan on going under the axel later this month. DVSST8 has one of the better set-ups ive seen. Search and you will find some examples.
Old May 2, 2006 | 11:22 PM
Drew's TA's Avatar
Yeah this is discussed almost everyday, and there are lots of pics, its not that bad to do and you will still have good ground clearance. just put you some flanges under the axle for when you use a jack on the car so you can unbolt it easy and the axle wont hit.
Old May 2, 2006 | 11:23 PM
SS4Luck's Avatar
awesome guys thanks
Old May 2, 2006 | 11:39 PM
TheBlurLS1's Avatar
That's what she said...
Check out the link in my sig. Tons of pics/info on it.
Under the axle works awesome. I have no problems with it at all. The clearance will be worse other places than under the axle, even better if you just reduce to 2.5" after the mufflers. The only problem is if you go over a large enough bump too fast, your suspension will unload and the swaybar will touch it.
