LT headers and tuning...
Old May 2, 2006 | 10:51 PM
wzup1000's Avatar
Default LT headers and tuning...
What exactly should be tuned after installing LTs? I thought it was just the air/fuel mix but is there anything else?
Old May 2, 2006 | 11:16 PM
Starz T/A 17's Avatar
rear o2 sensers need to get tuned out and if you take the egr and air pump off gotta remove those codes
Old May 3, 2006 | 02:26 AM
RrCoX22's Avatar
isn't this only if your doing a ORY? ....you still use the rear O2's if you have cats?
Old May 3, 2006 | 03:38 AM
LS1Lust's Avatar
Right, the computer will think something is wrong with your cats if you remove them. That will turn on your CEL, to tell you you need new cats
Old May 3, 2006 | 05:11 AM
Shallow Bay's Avatar
I'm pretty sure the only way the pcm determines whether or not the cats are working properly is from the rear O2 sensors. I don't believe the pcm can establish whether or not you have cats by itself.
Old May 3, 2006 | 05:15 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You either need Simms/Tuning when removing the cats.
Old May 3, 2006 | 05:28 AM
300bhp/ton's Avatar
I might be wrong on this but I thought with LT's and a catted Y you only used the front O2's which you need extenders for because they change location and the rears either need deleting or the use of O2 SIMS. As I say I may be wrong on this one.
As for tuning, well there's lots you can do it depends on your mods and setup. Removing torque management is a good idea as is raising your rpm limter and/or shift points (A4 only), A/F needs to be monitored and optimised as do the fuel trims. With an auto you can also select lock up points and kickdown points.
Cooling fan control can be adjusted, again for A4 guys you can alter the line pressure for firmer shifts if you want.
The list really does go on and on, best to check out the PCM forum for more info.
Old May 3, 2006 | 01:01 PM
RrCoX22's Avatar
ima little confused here guys... so when lt's are installed you must get the rear O2's tuned out? what is the reason for this? so basically when lt's are installed your only running the front O2 extensions? i had shorties put on and the shop drilled O2 sensor plugs into my rand. tech. cats that didn't have a sensor plug... are shorties a different deal? someone please fill me in... sorry the thread hi-jack!
 Michael S. Palmer
Old May 3, 2006 | 01:15 PM
sdbrown84's Avatar
The rear O2s are for emissions only. They let the car PCM know if the CATS are working properly. The front are the most important because they let the PCM know how to modify the A/F ratio. Shorties don't modify the stock CAT locations so unless you have changed out your CATS to high flow in your stock Y-pipe, you wont need to re-drill O2 bungs.
Tuning out the rear O2s will prevent you having to run O2 sims, which are only there to eliminate the SES light comming on after the rear O2's are deleted.
Hope this helps.
Old May 3, 2006 | 02:09 PM
LS1Lust's Avatar
Right, and that's what he is talking about, I think. The rear O2 sensors just let you know if your cats are working. So if you were to take your cats off and put them back on they would defenatly think something was wrong.
Old May 3, 2006 | 04:52 PM
2K2WS6TA's Avatar
Most, if not all, aftermarket y pipes don't have the mounting boss for the rear o2s (regardless if they're catted or off road) so you need to either tune them out, get o2 sims, or live with the SES light
Old May 3, 2006 | 06:40 PM
Robert Shelton's Avatar
Will o2 sims pass emissions? Have LT catted Y and need to pass here in MD. Tricking computer enough to get the sticker?
Old May 3, 2006 | 06:59 PM
ShevrolayZ28's Avatar
My Kooks catted y-pipe came with bungs for the rear o2 sensors. I still run the rears and I did not need extensions to connect them. I did, however need extensions for the front o2's.
