Need help on next mod
Old Nov 14, 2002 | 10:06 PM
Jimmy00Z28's Avatar
Default Need help on next mod
I will be getting my GMMG exhaustinaweek or so. I am part of the GP at the f-bodyhideout.com. Already sent in my M.O. I was just curious on what mod I should do next, everything else on my car is stock(FRAM air filter). I have done the free mods also. I have the !FRA so should I get a lid now or wait? My slave cylinder is going out now, so should I get a new slave cylinder and clutch. If so, which one would be best for everyday driving? My car is a 2000 Z28,M6. Any suggestions would be great!Thanks
Old Nov 14, 2002 | 10:15 PM
sited12's Avatar
Default Re: Need help on next mod
Ouch fram airfilter, not to sure about that choice. Get a K&N or Holley filter with a lid. All lids are the same so just take your pick on an after market one. Get some Nitto drag radial tires. And a new clutch. Now with those mods practice with the M6 and while you are in the practice stage save up for a 12 bolt or 9 inch rear end because yours is going to let go eventually. Then with the new rearend get a better gear. Probably 4.10 gears since you have a 6 speed. That should put you well on your way.
Old Nov 14, 2002 | 11:35 PM
1badZ28's Avatar
agreed
Old Nov 15, 2002 | 12:38 AM
FstBlkz28's Avatar
Get a Lid(many to choose from) and filter(k&n or holley)
Old Nov 15, 2002 | 05:38 AM
Jimmy00Z28's Avatar
The only reason I got the FRAM filter was because when I bought the car(used), they never changed out the stock filter from what I could tell. It was so dirty, I couldn't keep it in the car so I went out and bought the FRAM just for a replacement untill I get a lid. Thanks for the help so far, my next mod will be a lid and holley filter. Any more sugestions? Maybe after the lid? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 15, 2002 | 06:03 AM
LOnSLO's Avatar
Headers. Take your pick. Then cam, then rearend. Of course, if your slave is gone, I would get the clutch first. Might as well replace the stock one since you'll already be in there.
Old Nov 15, 2002 | 06:20 AM
unit213's Avatar
Administrator
I agree with sited12. Get a lid next. You should be able to find one used in the parts/classified section here. That'll be good for about a tenth.
Old Nov 15, 2002 | 03:42 PM
Jimmy00Z28's Avatar
What clutch setup would be good for me? I was planning on getting the Z06 clutch from gmpartsdirect, but should I get a mcleod or something like that?
Old Nov 15, 2002 | 04:41 PM
BLK02WS6's Avatar
Definetly the lid next and get a filter too because your FRA is gonna trash a paper filter in no time(I recommend the Holley - no stupid gasket)!
