Oil temp sending unit
Thanks in advance for any input,
John
you can not do this with it on the car.. take it off..
screw in your oil temp sending unit from autometer.. make sure you use teflon tap on the threads.
Here is a picture of the finished product for ya..
This is the tap drill size for the 1/8" -27unf NPT thread.
The hole is already there you just need to drill thru the 5/16" of material to finish the hole.
Tap the hole with the tap till there are 6 to 7 full threads remaining on the tap, if you go any deeper the sending unit will go to deep and may not seal.
A pipe tap is tapered about 1.5 degrees- so the deeper you go the wider the hole!
Hmmm, that sounds funny.
