which size of bullet?
Old May 4, 2006 | 04:32 PM
00 Freak's Avatar
Default which size of bullet?
I have a 2 7/8 in inlet and outlet bullet muffler sittin in my garage from my camaro. I want to use it on my new fbody. it has jet hot LT w/ ory, magnaflow catback. Should i leave my setup the way it is or will be able to make more pwr if i dump it before the axle. If so should i use the bullet already have or do need the 3in. Any advice.
Old May 4, 2006 | 04:35 PM
HowellSoccer88's Avatar
Just got done with this but I dumped it in front of the axle with no cats or mufflers...the i-pipe you are putting the bullet in is 2.75" so that tells you what size you need. Is it a Dynomax Bullet? I didnt see one that was 2 7/8 but I dunno...
Old May 4, 2006 | 04:38 PM
00 Freak's Avatar
Default size of bullet
I'm sorry 2.75in
