EGR removal question
Old May 4, 2006 | 05:49 PM
BirdmanLS1's Avatar
Default EGR removal question
So we got everything out except that tube that runs under the driver's side headlight. How do we get that out?? There doesnt seem to be any way to get it out...
Old May 4, 2006 | 05:53 PM
conan's Avatar
Are you talking about the air tube that goes from the pump to the air lid?? The egr is all on the passenger side. If the air is what your talking about, unscrew the black plastic cover inbetween the wheel and bumber (driver side) and remove the hole air pump and hoses.
Old May 4, 2006 | 06:00 PM
peterlawl84's Avatar
are you talking about the AIR pump and tube? the EGR should just be the small pump near the battery on the passenger side. if so unscrew the black plastic pieces from underneath and you can remove the whole pump and tube that way.
here is a write up... http://www.ls1camaro.net/sections.ph...ticle&artid=70
Old May 4, 2006 | 06:01 PM
RrCoX22's Avatar
eh dude... if you need help removing EGR/AIR go to www.installuniversity.com where they have step by step picture by picture directions
