SLP 85mm MAF
Old Nov 21, 2002 | 04:14 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default SLP 85mm MAF
Looking at pics of the SLP 85mm MAF, I see that it has a screen on it. I was wondering if one should do the stock 'port' trick by removing it?
Old Nov 21, 2002 | 11:32 PM
boomcase's Avatar
Default Re: SLP 85mm MAF
Just keep the stock unit
Old Nov 22, 2002 | 06:30 AM
unit213's Avatar
Administrator
Yup, what boomcase said.
Old Nov 22, 2002 | 09:22 AM
2002z28b's Avatar
yup what they said. i have the slp maf sensor. its ok, but i lost a little off the bottom, but i gained it on top. it revs harder in the upper rpm's. is it worth $150, i dont think so.
justin
Old Nov 22, 2002 | 10:42 AM
ls1290's Avatar
What are you guys running it with? I have a heavily modified 383 Stroker that I might put it on.
Old Nov 22, 2002 | 11:33 AM
2002z28b's Avatar
stock internals bolt on car. it might just work with you with some modified tuning.
justin
Old Nov 22, 2002 | 11:54 AM
promod1955's Avatar
theres guys runnin low 10's with the stock maf w/ the screen removed so it should be ok with your 383.
