Oil usage!
Old Nov 23, 2002 | 01:25 PM
John02SS's Avatar
Default Oil usage!
My car has never used much oil at all during normal driving, but will eat it at high RPM. Is this normal? During 3-4 autotap runs taking it to redline in 4th I will use 1/4 of a quart. Car is an 02' and this is the only time it uses much oil. Should I be alarmed? Should I look into the updated PCV? Thanks guys!
John
<small>[ November 23, 2002, 01:27 PM: Message edited by: John02SS ]</small>
Old Nov 23, 2002 | 01:48 PM
SSDude's Avatar
Default Re: Oil usage!
What kind of oil do you use? There was a problem with previous models of the LS1 using oil. But, that problems was fixed, so they say, when GM started using different rings. Are you using Mobile 1, Redline, or anyother synthetic? If not you should be using them instead if dino oil.
Old Nov 23, 2002 | 01:59 PM
John02SS's Avatar
I use Royal Purple 5w-30. The early cars used oil all the time and the 02 cars are better about it. Mine just does it at High RPM's, but after some looking around it seems they all do it somewhat.
