Tips for starter replacement?
Old Nov 23, 2002 | 07:52 PM
O2BQIK's Avatar
Default Tips for starter replacement?
Going to do it over the next few days, whenever I can find some spare time. Just looking for any tips or things one should be aware of. I found a couple posts on this by searching and they seemed to indicate it would be a piece of cake. TIA for any input.
<small>[ November 23, 2002, 07:53 PM: Message edited by: O2BQIK ]</small>
Old Nov 23, 2002 | 07:55 PM
Sears's Avatar
!Dial-up Director
Default Re: Tips for starter replacement?
It is really easy. 2 15mm bolts and it is out. Nothing complicated about it.
Justin
Old Nov 23, 2002 | 07:56 PM
Tin Indian's Avatar
There is no 'tricks or tips". Real easy. No shims envolved either.
Don't forget to unhook that battery first!
Old Nov 23, 2002 | 08:04 PM
O2BQIK's Avatar
Thanks guys, 'preciate it. Now I'm off to find a heat shield for it! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 23, 2002 | 08:35 PM
alexWS6's Avatar
Do you think the stock one went out cause of headers on the car? I am pretty sure this is what happened to mine, lately I've been having to shove a cane down there to knock it around and it will eventually start up <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Where did you buy the new starter and the heat shield?
Old Nov 23, 2002 | 10:04 PM
O2BQIK's Avatar
Alex, actually I believe it is heat from the passenger-side turbo that got to it. I got the starter from Valvegod (Shaun Carter) here on the board. I haven't ordered the heat shield yet...still working on that.
