drivability issue after LS6 intake swap
Sounds like a vacuum leak somewhere. There's only PCV, MAP sensor, brake booster, a/c vent door (tiny *** line in the back), EVAP, and fuel injectors that could be causing a leak.
Did you take the throttle body apart? The IAC plunger has an o-ring that can cause RPM fluxuation if left out.
