Torque Specs
Old May 9, 2006 | 12:36 AM
Thumper33's Avatar
Default Torque Specs
Is there a post on torqe specs anywhere?
Here's what I need:
Flywheel bolts -
Header Bolts -
Engine Mounts -
Pressure Plate -
Anything else I should really make sure it torqued right while putting the engine in.
Thanks!
Mike
Old May 9, 2006 | 12:40 AM
TheBlurLS1's Avatar
That's what she said...
http://installuniversity.com/install...sity/index.htm
Click install doc'c, then clutch install.
Header bolts should be done from the inside out at 11 ft/lbs, then a second pass in the same order to 18 ft/lbs.
http://ls1howto.com/index.php?category=1
Lots of specs on there.
