porting MAF...
Old May 9, 2006 | 03:29 PM
98hardtopZ's Avatar
Default porting MAF...
i got the maf out and the two metal halves apart, now to remove the screen. does it just rip all to pieces coming out or is there a way to re-use it?
Old May 9, 2006 | 03:31 PM
TheBlurLS1's Avatar
That's what she said...
Is this some kind of a joke?
Old May 9, 2006 | 03:38 PM
98hardtopZ's Avatar
im guessing you just rip it out?
Old May 9, 2006 | 03:50 PM
sdbrown84's Avatar
DONT RIP IT OUT!!! People have made too many mistakes porting the MAF and a removal of the screen will most likely cause problems.
Old May 9, 2006 | 03:56 PM
daryl2cb@yahoo.com's Avatar
yes leave it alone, no proform gains really got in here.
Old May 9, 2006 | 03:59 PM
presto_z's Avatar
i removed mine, just by gently prying it out (yes there is such a thing), the sides will crinckle and the screen will be garbage....i did mine with no negative effect on the car although there are many peole who have had this mod and have had problems w/ how the car runs....this is a fairly common subject so if u search there should be plenty of info..
p.s. i didnt port mine, i just removed the screen..maybe 1 hp gain at max on stock motor maybe slightly more for a more built motor.... looking back the risks arent worth the gain... but i guess i was lucky... the choice is up to you
Old May 9, 2006 | 04:05 PM
98hardtopZ's Avatar
thanks for the answers and not, "is this a joke?" if it were a joke, would i be asking? i just dont want to tear shi* up on my car. im just going to reassemble and purchase a granetelli down the road.
Old May 9, 2006 | 04:20 PM
John_D.'s Avatar
That comment is because this is probably the A-#1 mod not to make, that has been discussed over and over again.
Note the user title for the person who posted that comment...
Not that you should already know this, but a little searching and reading some of the sticky's would go a long way.
Old May 9, 2006 | 04:22 PM
98hardtopZ's Avatar
i did, where do you think i got the idea?
Old May 9, 2006 | 05:56 PM
TAQuickness's Avatar
Yes. I'm surprised the search button director didn't jump in and deliver the punchline
Old May 9, 2006 | 06:00 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I almost said something as well. Don't jack with the MAF unless you plan to SD tune and remove it alltogether.
Old May 9, 2006 | 06:33 PM
ws6formula98's Avatar
My friend with a 02 ws6 dyno his car and made 328, so he was runing rich and took of the the srceen and got 8 hp
Old May 9, 2006 | 06:35 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is refered to as "luck". Everyone has that "friend" too btw
Old May 9, 2006 | 06:42 PM
Phynix's Avatar
I descreened mine and ported it myself and it runs great, first time I ever did it.
Old May 9, 2006 | 06:55 PM
98TADRIVER's Avatar
mines ported and descreened, picked up 1 tenth!
Old May 9, 2006 | 06:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine is descreened too, but there was no difference. If you still have a completely stock MAF, a good rule of thumb is to not mess with it.
Old May 9, 2006 | 11:27 PM
TheBlurLS1's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/446140-so-i-broke-my-maf.html
I've seen this WAY too many times.
