Best gauges??
Old Dec 4, 2002 | 04:15 PM
WJ SOM SS's Avatar
Default Best gauges??
AutoMeter's best gauges? Electric or mechanical? What lasts for rigors of drag racing vibrations, etc.? Cyberdyne's? Opinions, please. 4th gen. F-body pod mount installs only, please. Thanks. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Dec 4, 2002 | 04:20 PM
MIGHTYMOUSE's Avatar
Default Re: Best gauges??
pro comp is autometers best set of gauges, or even the liquid filled ones. 2 5/16" is the size you need, some are mechanical and some are electric depending on what you want your gauges to read.
Old Dec 4, 2002 | 07:04 PM
SSDriver's Avatar
Some gauges you have to get electric(ie: volts, tach) but others you have a choice of mechanical(ie: water temp, oil pressure). I personally think that mechanical gauges are more accurate. For instance your puting a water temp guage in. The mechanical guage has water flowing all the way to the back of the guage, where in an electric version you have a sensor reporting back through a wire what the sensor reads(more room for error). Its kind of like cable/fly by wire, cable has much better throttle resposne IMO, becuase it is DIRECTLY hooked up to the source.
