air intake question. need help quick
Old May 11, 2006 | 04:48 PM
ssmaro's Avatar
Default air intake question. need help quick
This may seem like a horrible question but I'm trying to change my lid right now. And I'm trying to get the lid/maf/bellow to come off in one piece. Well there are these little black plastic screws that are holding the whole section down and they won't come out. There in between the lid and maf holding the black plastic down. Should I rip them out or should they come out? Thanks
Joel
Old May 11, 2006 | 05:25 PM
2K2WS6TA's Avatar
Unclip the lid, and then take a flat bladed screwdriver and loosen the clamp where the bellows and the throttle body meet, pull the bellows off the TB, and there you have it, the whole assembly, off in one piece
Disconnect the electrical connector for the MAF, and the IAT sensor before removal (otherwise you'll be pulling wires out of connectors, and that's bad)
Tho why you want to take it all out when you don't need to I couldn't guess, just unclip the lid, loosen the clamp, grab hold of the MAF and pull the lid off, install is reverse of removal
Here's a pic to help you(thanks to LS1howto for the pic
