LS6 D-shaped exhaust ports
Old Dec 11, 2002 | 04:54 PM
Gary Z's Avatar
Default LS6 D-shaped exhaust ports
Does anyone make headers that are port-matched to the "D" shaped exhaust ports of the LS6 cylinder head? Do the stock Z06 Corvette exhaust manifolds have "D" shaped ports? My searches have only revealed that the "D" shape resulted from a discovery that raising the floor of the port improved flow. There can't be anything magical about a "D" shape. At any given point along its path, the gas only cares about cross-sectional area; it can't tell what shape that area is. The designers of the LS6 head must have intended that there would be a smooth transition into the exhaust system. Is this typically accomplished by "rounding" the exhaust ports? What do you meticulous guys do about this?
TIA Gary
Old Dec 12, 2002 | 08:44 AM
NICK FILIPPIDES's Avatar
Default Re: LS6 D-shaped exhaust ports
GARY, THE STOCK EXHAUST MANIFOLDS ON THE LS6 HAVE OVAL EXHAUST PORTS NOT D-SHAPED. WE CAN BUILD YOU A SET FOR YOUR CORVETTE IF YOU WISH.
NICK KOOK'S HEADERS
