Need Some Help
Old Dec 14, 2002 | 09:45 AM
dug's Avatar
dug
Default Need Some Help
How do you remove the center piece under the intake? Its got the holes for the 2 knock sensors. I need to get it off so I can change the oil pressure sensor. Im in the process if changing the intakes and broke it while I took the old one off.
Old Dec 14, 2002 | 09:56 AM
Gimp98TNT's Avatar
Default Re: Need Some Help
It's pretty easy first disconnect the wires going to the two knock sensors. Then remove the two sensor with a socket and ratchet not sure on what size but its big like 24mm or somthing like that. Then just take all the bolt that hold down the cover and it should come right off.
Old Dec 14, 2002 | 10:28 AM
dug's Avatar
dug
Thanks Gimp.
One more thing, who do you disconnect the wires from the knock sensors? Its probably really simple but Im not getting it.
Thanks
