How Do You Unplug the Knock Sensor Under the Intake?
Old Dec 14, 2002 | 11:33 AM
dug's Avatar
dug
Default How Do You Unplug the Knock Sensor Under the Intake?
I need to get the middle piece out so I can change the oil pressure sender.
Old Dec 14, 2002 | 02:22 PM
dug's Avatar
dug
Default Re: How Do You Unplug the Knock Sensor Under the Intake?
ttt
Anyone? I could really use the help. Im stuck. Cant get figure out the connectors for the knock sensor.
Nevermind. I did a search like I was suppose to in the first place.
<small>[ December 14, 2002, 02:27 PM: Message edited by: dug ]</small>
Old Dec 16, 2002 | 11:59 AM
OneQuickSS's Avatar
the plug for the knock sensor is behind the intake. Its way back there, so good luck.
Old Dec 17, 2002 | 12:20 AM
ApacheDrill's Avatar
There is a special tool that you need to replace the switch as well.. good luck its hard to do with the intake on.. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
