removing engine?
Old May 14, 2006 | 01:37 PM
SVC707's Avatar
Default removing engine?
this is how it sits right now... transmission still attached. should i just unbolt the transmission from the back side of the motor or pull it out with the transmission. i plan on putting it back in the car with a new k member from underneath fully assembled with wires and manifold already bolted on. but im getting the itch to do something while waiting for the motor to get finished.
Old May 14, 2006 | 01:48 PM
SiL3NtXWS6's Avatar
You could get it out the top so easily with just that. It's not that hard when the re's nothing on the block. Leave the tranny attatched when you pull it too.
Old May 14, 2006 | 02:02 PM
SVC707's Avatar
what should i bolt the chains too. im can use the one on the side where the alternator wasm bolt is sticking out now. or just put it where one od the heads bolts were?
