little add-ons
Old Dec 25, 2002 | 01:22 PM
last of the Z28's's Avatar
Default Re: little add-ons
ok i can understand the iac thing but why wait on the maft?does it have internal programming?does slp just flow better with no programming?speed inc is advertising 18 hp with the zo6.soory this stuff is new to me!
Old Dec 26, 2002 | 12:30 AM
Default little add-ons
i was curios...i have a 2002 z28.my current mods are....stealth intake,lm exhaust,and a body kit(got a good price on that(used)so i couldnt pass it up..looks like the zenon but has no logos on it?)anyhow....i was curious if adding stuff like a zo6 maft or slps iac tricker is worth it in the long run?i plan an building it up either n/a or power adder but will these parts hurt me in the reprogramming or tuning of the car later on?man i have so many ?s its hard to put it in a simple post!i'll wait for a reply though before i get to crazy!!!!!!by the way merry x-mas!!! <img border="0" alt="[Driving]" title="" src="graemlins/gr_driving3.gif" />
Old Dec 26, 2002 | 12:49 AM
Boo Yeah's Avatar
wait on the maf, or get an slp, don't do the air temp module, mine i had sucked. As soon as you get any type of cpu tuning done you will no longer need it, so save the money,
Old Dec 26, 2002 | 12:54 AM
Boo Yeah's Avatar
what do you want this car to do? Autocross, DRAG, combo??? Also do you have any hp or time goals.
Old Dec 26, 2002 | 01:07 AM
CAT3's Avatar
Restricted User
MAF-T is a good tool, once you start changing the basic structure of the combustion process it is more important. Being basically stock you may only get a little out of the MAF-T, but after a lid, intake, ported TB, Z06 maf or Ported MAF and exhaust etc...the MAF-T becomes more of a power adder. Basically the unles syou have LS1-Edit, the MAF-T is an invaluable tool as you can tune the A/F as you build the car. Once you get LS1Edit, you simply unhook and sell it.
For the timing tricker you can do the "free mod" as detailed in I believe installuniversity.com or do a search here or any of the boards. Buying an actually tricker may not be worth it, but a couple dollars on a resistor or whatever is worth it IMO.
Boo Yeah is right though, what your goals for you and your car should known so you can make yourself a mods planner and track your progress. Good-luck.
Charlie.
