GOT NEW DYNO NUMBERS BUT QUESTION??
I got my 2002 WS6 dynoed second time with 3800miles yesterday at SPEEDTEK. I made 333 rwhp and 347 torque consistently on 3 runs.
Previous dyno at 1285 miles, I made 332 rwhp and 343 torque {lid. filter, exhaust cutout). Only differnce between 1st and 2nd dyno is that I have added an ASP pulley.
Although I am still happy with my numbers and I do notice much better throttle repsonse with pulley but I was expecting to see an increase by 8rwhp with an ASP pulley and I got just 1rwhp and 3ft-lb of torque gain.
Is this normal? Pls see my dyno graph in link below. DYNO1 is older and DYNO2 is recent.
http://community.webshots.com/user/adnanx786
Pls comment on the graph. My AFR was a little below 12 as u can see in the graph? Should I use MAFT to take it to 13....how much rwhp with this release?
Thanks,
Adnan K
__________________
2002 WS6 M6
1st DYNO @ 1285miles on 08/31/02 Max RWHP=331.8
Max Torque= 343.4
ASC Conversion Date: May 22nd 2002
ASC Conversion #: 9064
Ext Color: Bright Silver
Int Color: Ebony
Hurst Shifter, Direct-Flo Lid, Cut-Out 08/31/02
TB-bypass, Free ram Air, BMR SFC, ASP Pulley 10/13/02
2nd DYNO @ 3800 miles on 12/28/02 Max RWHP=333
Max Torque= 347
i think you'd gain an easy 5-10 hp with a better a/f ratio.
it's hard to tell the a/f ratio on your first dyno though (looks around 12.0).
Your CAT over temp seems to be kicking in too since your A/F gets fat right at 5000RPM. As long as you have CAT's you may want to try LS1_Edit to adjust this by adjusting the temp. If you delete the CAT's you can always disable this feature and have a table top smooth A/F which in my case was good for ~12RWHP <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
