crank pulley problem
Old May 17, 2006 | 07:02 PM
Big Budda's Avatar
Default crank pulley problem
I stripped the first few threads in the crank . After taping it out it seems to be alright.
My question is should I be worried about stripping them even more when I install the pulley?
If so is there any other way to install the pully on the crank.
Any ideas?
Old May 17, 2006 | 07:43 PM
67Ranger's Avatar
a piece of threaded rod, a washer, and a nut. Also, many people will bake the pully before they put it on, so that it expands and goes on easier
Old May 17, 2006 | 08:22 PM
Big Budda's Avatar
thanks
Old May 17, 2006 | 09:10 PM
TheBlurLS1's Avatar
That's what she said...
Make sure you run the old bolt all the way in and out a few times to make sure it's not going to get ugly.
I would put the pulley in the oven for a while before you try to install it with the threaded rod/washers/nut as mentioned above.
After you get it fully seated, remove the nut/rod and install the new bolt. You might want to be a little less crazy on the new bolt considering the lack of threads.
Old May 18, 2006 | 02:54 PM
MavrikTA's Avatar
I agree. And dont be concerned about the threads in regards to retaining the pulley. The pully will actually stay on without the bolt, though I certainly would not recommend trying it!! Scary, huh!? The hub is tight enough that it aint goin anywhere. Just a little input in case you were concerned!
Old May 18, 2006 | 03:06 PM
dregnier0's Avatar
BAke it and get a longer bolt.
2x4 and a hammer also helps to pound it onto the snout.
Old May 19, 2006 | 08:23 PM
Big Budda's Avatar
thanks guys worked like a charm
Old May 19, 2006 | 09:07 PM
daryl2cb@yahoo.com's Avatar
1 inch longer bolt to start to thread is the best defence against that
 Michael S. Palmer
Old May 19, 2006 | 09:51 PM
Iron Sights's Avatar
Or a wooden board and a rubber mallet! I noticed some rubberish material on my SLP pulley and chose not to bake it; was this really an issue or was I being paranoid?
Old May 19, 2006 | 11:56 PM
TheBlurLS1's Avatar
Well it's designed to take AT LEAST 300* (think of how hot the car gets), plus there's probably a saftey factor.
The reason it's so hard to get on while cool has alot to do with how tight they want it to be when it heats up. Being supertight while cold preloads it so it'll stay tighter at operating temperature.
