Performance Shops in Central TX????? EXHAUST HELP!!!
Old May 17, 2006 | 09:47 PM
Llust1WS6's Avatar
Default Performance Shops in Central TX????? EXHAUST HELP!!!
so, i'm trying to find a good performance shop in the san antonio/san marcos/austin TX area where i can get a deal on an exhaust set up at. i've considered doing the install myself, but working 60 hr weeks leaves me with little time to wanna deal with it. i've tried running some searches on google, but i dunno, i just can't seem to find any shops. any help would be AWESOME! also, i'm still debating on the exact set up i want to roll with. i've been on ls1sounds.com and listened to just about every audio file, but cannot make up my mind. i think right now i'm primarily considering the following:
-SLP LM (maybe a tad too raspy from what i've heard?)
-GMMG (not quite loud enough?)
-True Dual of some kind (clearance/complicated set up to run out back?)
i've only had the car for about a month so it's essentially stock with some minor exceptions. the eibach prokit will be comming soon too, so clearance is also a consideration w/ the true dual especially. i know that a lot of this boils down to preference in sound, so a heads up... i want something LOUD, good hp gains, nice deep/low tone, not too raspy.
HELP ME GUYS!!!!!!
Old May 18, 2006 | 06:30 PM
TheBlurLS1's Avatar
That's what she said...
https://ls1tech.com/forums/sponsors.php
Enter your zipcode and mileage.
You could try this in the regional forums. Do lots of reading to help decide on your setup. We can't tell you what you'd like.
Old May 18, 2006 | 06:35 PM
Latin-Man's Avatar
I know of somebody here in Dallas, (North Richland Hills actually). this shop does custom work and does a "simulated" fit to see if you like and got the ground clearance your looking for. its not cheap, pretty expensive if you want to go the custom route.
hope that helps
