Pictures of a borla X R-1
Old Jan 2, 2003 | 12:37 AM
roadrunner-r's Avatar
Default Pictures of a borla X R-1
In place of the slp bullet. I was thinking of using a magnaflow 4"x 9 is this to big?
Old Jan 2, 2003 | 02:51 AM
Dope's Avatar
Default Re: Pictures of a borla X R-1
I don't think you're gonna fit a Borla XR-1 in place of the resonator. Not enough room.
Go to http://www.borla.com/motorsports/?ca...866.30.228.180 and check out the XR-1 lines of mufflers. I think they are typically like 4.5"x8" or so. You might be able to fit them vertically but not horizontally.
Dope
Old Jan 2, 2003 | 03:40 PM
What muffler can i put in there? Is the mangnflow to big? 4"x 9
Old Jan 2, 2003 | 05:03 PM
Dope's Avatar
Assuming that's 4" around and 9" long, yeah, that'll fit fine.
Most people put dynomax bullets or chambered mufflers or resonators in the i-pipe. You really can't fit much more than 4" diameter mufflers in there, and even that is pretty close.
Dope
Old Jan 2, 2003 | 05:15 PM
I just wanted to use that one muffler. Just like a loudmouth. Its quiter they the dynomax bullet,and the slp res. anybody have a pics? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 2, 2003 | 05:29 PM
ratio411's Avatar
The DynoMax bullet 24222 is not nearly as loud in there as some folks think. Until 3k rpm it is actually fairly quiet. After 3k it screams pretty good though.
The LM is louder.
If you wanted to go quieter with the bullet, use the long bullet... DynoMax 24219.
If that 4x9 means 9 wide, 4 tall, you don't have a chance. The 4 wide bullet is very close to the driveshaft.
Dave
BTW: I have 3 sound clips with the short bullet on page 2 of my webpage.
One is mostly idle. (quiet)
One is WOT accelleration. (loud)
One is a dyno run. (through the gears nice and easy, then WOT)
Old Jan 2, 2003 | 06:49 PM
Bad Blu Formula's Avatar
Actually you can install an XR1 in place of the resonator because Crager who posts on here has done that.
Old Jan 3, 2003 | 02:02 AM
does he have any pictures of it?
Old Jan 3, 2003 | 01:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've got some 12" XR1 sportsmans on my duals, you can see them at www.ls1tech.com/psjpics...
The mufflers are not very tall.
Old Jan 4, 2003 | 12:58 AM
Dope's Avatar
I would like to see pics too, and know what model XR-1 he used.
Dope
