Faulty catalytic converter causing detonation?
The plug change seemed to help the pinging before I took it in to the dealer but could a converter on its way to going bad have contributed to the detonation? I'm thinking a combination of fouled plugs and a faulty converter was the cause of my pinging. Also, what are the chances that the Amsoil Power Foam caused the converter blockage/failure? Thanks...
the likelihood of the amsoil cleaner causing the failure is negligible. if nothing else it puddles up in the intake until the engine reaches operating temp which evaporates it as designed to do.
