Here's my Pacesetter LT's
Old May 18, 2006 | 03:58 PM
SSmokin99's Avatar
Oh and my ported TB should be in tomorrow. Let me know everything I need to install these things. Thanks to all
Old May 18, 2006 | 04:03 PM
bmfcamaro's Avatar
pacesetter coating sucks. it looks like that within a year.
Old May 18, 2006 | 04:18 PM
My2ndls1's Avatar
You'll definitely love them!! Are you also removing the EGR? I assume so if you're installing an LS6 intake. If so, hold off on the O2 sims, you're going to throw a code anyways for the !EGR, just get it tuned out. You can reuse any of your O2 sensors for the fronts, you just have to extend them a little. Either do it yourself or buy some O2 extensions. The only other thing is be sure to use anti-seize on the bolts and possibly some new header gaskets if you're old ones are bad. Mine looked OK, but I replaced it anyways for cheap insurance! Other than that, a little time and patience. Good Luck!
Old May 18, 2006 | 04:19 PM
The PAT WS6's Avatar
how much did u pay for them?
Old May 18, 2006 | 04:25 PM
SVThis's Avatar
**** mine dont look like that...the bottom of them had a lil surface rust on them but i just sanded it off and recoated them...
TheBlurLS1's Avatar
That's what she said...
Read the stickies, there is a few install writeups in the exhaust FAQ. You should also check out he AIR/EGR FAQ to adress those problems.
That's not a hole in the #2 primary is it?
Old May 18, 2006 | 05:02 PM
SSmokin99's Avatar
I paid 325 shipped!
Old May 18, 2006 | 05:03 PM
SSmokin99's Avatar
Yeah, I'll be deleting the EGR. What's anti-seize? I was thinking of getting new bolts. I'll also be buying new gaskets.
Old May 18, 2006 | 05:05 PM
SSmokin99's Avatar
It looks like a spot that got burnt. He said there was only like 7K miles on them. There is also a little dent in them.
Old May 18, 2006 | 05:07 PM
SSmokin99's Avatar
I'll post some close up pics in about an hour or two
