Throttle body hole size help
Comp XER grind
228/228
581/581
2 degress advanced
112 lobe seperation
My TB hole is at 13/64 with a 800rpm idle for my 221/221//.558//.558//114 cam. My IACs are in the 45-50 range...I am planing to enlarge the hole further or start a new smaller hole in the spring to get my idle a little more stable.
with the AC on. I have the hole drilled to 15/64"
It was better but the real fix was to add a
.022" ( 26ga tin i think) shim on top of the idle
set screw.. go to big and you will throw a
high idle code.. this is the old Trooper Mod.
I have no idle problems at all now..
