Where do I need to go next
Do you have a M6 or an A4? It sounds like you're headed in the right direction. Don't overlook tires. Get a converter if you have an A4. I don't really consider that a bolt on mod though.
BTW, you're poll is screwed up.
I don't think what you have listed there will be enough to go 7s in the 1/8th. I was running around the 8.0 mark when I was in the 12.7 range, and what you've got there probably won't get you to the 12.7s unless you've got a real freakishly fast LS1.
