Which jet-hot header .....help
Old Jan 14, 2003 | 04:30 PM
fak005's Avatar
Default Which jet-hot header .....help
I have a 2002 WS6 and am planning on geting the new jet-hot headers. Since my car has AIR but no EGR,
Now can u recommend which batch should I get - (1)the one with EGR and AIR or (2)the one without EGR and AIR. Unfortunately
Jet-Hot do not have any option for headers that have AIR and no EGR.
Pls tell me which would bean easier route to take i.e. requiring least amount of changes.
Thanks,
Adnan
Old Jan 14, 2003 | 07:31 PM
35th LE SS's Avatar
Default Re: Which jet-hot header .....help
I have a 2002 SS and I bought the Jet Hot headers w/ air and egr. I got a set of used air tubes (as 1998/1999 are different than '02) and the egr block off plate and air resctrictor plates.
If you go the no air/no egr, you'll need block off egr and air plates. Some guys also remove the air pump as well.
It's probably half a dozen or the other. If you want a cleaner look then the no air/egr will be better if you remove the air pump.
