Wondering why 4 O2 bungs in MAC ORP?
What would happen if I used no cats, and hooked up all the O2 sensors in the stock configuration. Would I throw codes because the rear sensors' readings would show the cats (which are missing) are not working properly?
Just wondering....
It seems like if you buy an ORP, MAC might as well eliminate the rear O2 bungs since you will probably be running SIMS anyway... or do the SIMS connect "between" the sensor and the PCM, so the holes are still needed?
Thanks!
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
You can leave the rear O2's to plug the hole when you get the simms, or just get a little bung hole plug to screw in there. You remove the O2 wiring harness, and snap the simms in place.
