finally changed pcv on a 98
Old Jan 21, 2003 | 08:07 AM
jpz28's Avatar
Default finally changed pcv on a 98
I finally figured it out after trying to mess with it and I did switch it....for a 98 its all up on the valave cover top and it was all wrapped in some kind of black foam stuff and then wrapped with black tape....So I went ahead and took off the tape and the black foam stuff and changed it...but after I switched it back...I couldn't get any of the black foam around it anymore or even put new tape on it....would this cause any problem???......I made sure the valve was all the way in on both sides of the fitting!!!...in other words does it need to be covered?......It just exposes a little bit of it....but hardly any...
Old Jan 22, 2003 | 12:29 AM
felton316's Avatar
Default Re: finally changed pcv on a 98
No, it doesn't need to be covered. It'll be alright.
