What sealant on coolant temp sensor?
Old May 24, 2006 | 09:08 PM
Miles in Florida's Avatar
Default What sealant on coolant temp sensor?
The service manual says "P/N 12346004 or equivalent",and 12346004 is GM Pipe Sealant, with Teflon. I asked at the parts store, and they said to use anti-seize. Is that right? If not, what should I use?
Thanks.
Old May 24, 2006 | 10:02 PM
2K2WS6TA's Avatar
Use pipe sealant with teflon, the liquid, not the tape you can get that at your local hardware or auto parts store
The anti sieze won't seal and you'll have a coolant leak
Old May 25, 2006 | 09:30 AM
GuitsBoy's Avatar
I used the teflon tape with good results. Ive also used permatex thread sealer, not sure if it contains teflon though.
Old May 25, 2006 | 01:47 PM
The GM pipe sealant was $21 for 0.5 ounces. Permatex pipe sealant with teflon was only $5 for 4 ounces. I went the cheap way, I'll post again to this thread if it leaks.
Thanks,
Miles
