Code P0160
Old May 28, 2006 | 08:33 AM
NOS99HAWK's Avatar
Default Code P0160
I just got this code yesterday, is it front or rear O2s? I have LT headers, no cats with rear o2 simms.
THXS
JR
Old May 28, 2006 | 10:56 AM
ShevrolayZ28's Avatar
THXS
JR
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
Make sure you don't have a loose connection at the sim. But it's quite possible that your o2 sim is no longer tricking the PCM.
If the problem is not a loose connection, then your best bet is to have someone remove this diagnostic from the PCM, or I suppose you could try another o2 simulator.
Try doing a search, this is a common problem.
Old May 28, 2006 | 11:41 AM
TheBlurLS1's Avatar
That's what she said...
Search.
https://ls1tech.com/forums/generation-iii-external-engine/509539-water-got-up-intake-what-now-all-diagnostic-trouble-codes-dtcs-inside.html
Old May 28, 2006 | 10:39 PM
Shallow Bay's Avatar
It's the passenger side rear O2 sensor.
Old May 29, 2006 | 12:18 AM
TheBlurLS1's Avatar
This means your O2 simulators aren't doing their job. You could pull the PCM BATT and PCM IGN fuses from under the hood and let the car sit for about 10 minutes to get rid of the SES code, hopefully it won't come back on.
Old May 29, 2006 | 12:31 AM
SHINER's Avatar
sometimes i get some wierd code number saying "unknown fault"
