SES P0302 Misfire after Headers
Old Feb 3, 2003 | 05:21 PM
A-Train 02Z28's Avatar
Default SES P0302 Misfire after Headers
I got a number two cylinder misfire. I replaced the spark plug and the problem went away for about a day and before you know it the light came on again for the same problem. I have found no leaks in the exhaust. I did notice where the air tubes on the mac headders hook up. I can see a spark when someone opens the throttle. So maybe a leak there. I have ordered new plugs and wires. They will be in tommorrow. Any other suggetions? Thanks guys.
Old Feb 3, 2003 | 08:12 PM
wrencher's Avatar
wrencher
Default Re: SES P0302 Misfire after Headers
No that is it plugs & wires. If you can see it arc out. + add a dab of die-electric grease on plug end of wire, helps insulate wire end to plug.
