Intermittent skip
Old May 30, 2006 | 07:38 AM
Big Geek's Avatar
Default Intermittent skip
My car has an intermittent skip that is driving me nuts. I am wondering if it could be related to my coil packs vibrating; here is my reasoning. I did as many others and did not put all of the bolts back into the coil pack brackets. I did the front ones and left the back two (See PITA ones.). Could the vibration be causing a misfire? HP Tuners only lists it as a misfire, no particular code that I found. What gives? It does it with both the N/A program and the N2O tune. I also wondered if it might possibly be where I have crimped off the EGR tube. I need to weld up the header tube there as it has developed an exhaust leak. Is there any reason it would be picking that up as a misfire? One last question for you good folks - is there any validity to having to disconnect the battery before welding on the EGR tube. I am sure this was NOT done when my exhaust was done but have heard a few mention it before regarding causing PCM issues. Is this true or just an old wives tale? Thanks in advance for any and all help.
Jim C.
Old May 30, 2006 | 08:51 AM
Big Geek's Avatar
What a load of ****!!! From what I am reading here this could be caused from the vibration of my driveshaft as well. Well I guess I will have to start elimating things one by one. It also says that it could be caused by failing the EGR/AIR tests. I thought all of that was turned off when I paid for my tunes. I guess I will have to find out how and where to check it at. Any pointers? Thanks.
Jim C.
Old May 30, 2006 | 11:52 AM
kpowr82's Avatar
Double check your plugs and wires, especially the number 8 wire.
