Y-PIPE RUBS
Old Feb 6, 2003 | 09:30 AM
jellis's Avatar
Default Y-PIPE RUBS
I just lowered my car 2" and on the drivers side of the y-pipe hangs down lower than the pass side is there a way to fix it or is there another Y-pipe I can buy that will sit up higher than the stock pipe? If so where is the best place to by one? Thanks
Old Feb 6, 2003 | 08:30 PM
Dope's Avatar
Default Re: Y-PIPE RUBS
Good luck, you raise it up much higher and it's gonna bang the floorboards. Think the stock y-pipe has the best clearance of any aftermarket setup.
Dope
Old Feb 6, 2003 | 10:08 PM
ChiTownSS's Avatar
Definitely don't buy the SLP Y pipe if it is clearance that you are looking for. Mine hung down lower than my FLP's & Y pipe do. That's the reason GM bent the stock one to hell on the drivers side.
Old Feb 7, 2003 | 01:31 PM
zoomer02's Avatar
I just put on a drive shaft loop and had the Y pipe bangin it. When I adjusted the Y-pipe one sid was hanging down lower than the other. The way I corrected this was to loosen the Y-pipe at the three connections but did not remove the hanger. Now I put a piece of wood of the correct thickness on the passenger side to maintain clearance then I put the floor jack on the drivers side Y-pipe and lifted it up to the correct position. The wood kept the pipe from getting too close on the passenger side then I tightened up the bolts to the y-pipe at the three joints. Good luck. I think this will fix it.
