Quick ASP Pulley (crank only) question...
Old Feb 7, 2003 | 05:46 PM
BillWS6Formula's Avatar
Default Quick ASP Pulley (crank only) question...
I'm getting set to swap in the ASP crank pulley and after doing a search I've found the following info:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> 378K4 Belt for AC Pulley $10.99
760K6 Accessory Belt for ASP Crank Pulley Only
$17.99
770K6 Accessory Belt for ASP Crank & ASP Underdrive Alternator Pulleys
$17.99
755K6 Accessory Belt for ASP Crank & ASP Overdrive Alternator Pulleys
$17.99 </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">But my dumb question is when doing the crank pulley ONLY, do I need the new AC belt as well as the accessory belt?
TIA... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 7, 2003 | 06:06 PM
MOBE's Avatar
Default Re: Quick ASP Pulley (crank only) question...
Yes. LS1s have 2 belts. If doing the crank pulley only you will need the 76" belt for the crank and accessories and the 37.8" belt for the a/c.
Old Feb 7, 2003 | 07:30 PM
Thanks! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
