Need help with vaccum problem when I removed AIR and EGR
Ok the AIR and EGR are off the car now after my heads/cam swap...but my question is...does the vaccum port on the rear of the intake manifold get plugged off or do I hook vaccume hose up to it...because when i removed the check valve i think that check valve hooked up to the intake manifold port..but I found a vaccum line coming out of my wiring harness so I shoved that onto the intake port in the rear...is this correct?? lol i took it off 3 months ago and i forgot where everything goes <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> please help me...
carter
carter
