Dropping Cradle... A few quick Q's
Old Feb 9, 2003 | 12:58 AM
ONE BAD BIRD's Avatar
Default Dropping Cradle... A few quick Q's
OK I've got almost everything ready to go now. I dropped the cradle down about 4 inches, so I could get at everything on the top of the engine. There are a few more things I need to know before I can finish.
-How do I get the fuel lines off! I got the low pressure line off, but the silver one, I can't get off! I took that little clip and the rubber off, but it won't come! What do I do?
-Starter wires... Should I have unhooked these? I unplugged all the harnesses from the top, but me thinks I might have to take them off at the starter?
-Clutch! How do I disconnect the hydraulic line? (M6)
I think thats about it, help would be appreciated!
Old Feb 9, 2003 | 01:20 AM
BYBYC5's Avatar
*Bad Trader*
Default Re: Dropping Cradle... A few quick Q's
yes undo the starter wires,
fuel lines, you need a fuel line disconnecter(gm style) autozone or any autoparts store should have,real cheap.they are little white plastic things.
clutch, have no idea i have an A4
Old Feb 9, 2003 | 08:36 AM
DaddySS's Avatar
Here's what i can find in the manual:
Using J 36221, depress the white circular release ring on the actuator cylinder hose and simultaneously pull lightly on the master cylinder hose to disconnect.
Protect both hose coupling ends from dirt and damage.
Old Feb 9, 2003 | 11:35 AM
OK is there anyway to disconnect the fuel line without a tool? I don't have access to one and I'd like to get this done today.
Old Feb 9, 2003 | 01:21 PM
Damn I guess the motor won't be coming out today then <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Still can't figure out the clutch though!
Old Feb 10, 2003 | 12:44 AM
BYBYC5's Avatar
*Bad Trader*
nope, no way
