Air/Fuel Gauge install ?????
Old Feb 9, 2003 | 01:54 PM
tim99ws6's Avatar
Default Air/Fuel Gauge install ?????
hey i need a little help installing my air fuel gauge, wondering if you guys could help.
i have a 1999 ws6 with LT's and o2 sims. i have wired everything else except for the purple wire, the actual wire that reads the air/fduel ratio. my question is what wire do i splice into to get the gauge to work, and where do i splice in at?????
any help would surely help, as i am basically done w/ the install, and this sucks....
Thanks~!!!
Old Feb 9, 2003 | 04:47 PM
2002snortbird's Avatar
Default Re: Air/Fuel Gauge install ?????
Try this site http://www.ls1.com/2002pcm.htm
Old Feb 11, 2003 | 08:43 AM
SMOKINV8's Avatar
Or you could find a sponsor that sells the little 3" O2 extender with an extra wire run out of it, made specifically FOR the A/F gauge.
Usually run around $20. Just decide if keeping it a clean install is worth it to you.
BTW, where'd you chose to run your wire through the firewall at?
