Car won't start, need help diagnosing the problem.
Old Feb 12, 2003 | 01:06 AM
EddyZ28's Avatar
Default Car won't start, need help diagnosing the problem.
I tried starting my car today and it turns on for a few seconds, then it starts to shake, then the idle goes real low and then it stops. Even if I press the gas, the car dies. I took off the battery and alternator and had them checked out. The battery was ok, but since it was getting a little old I bought a new one. I got the alternator checked out and it works fine. What should I try out next? I Autotaped the car and here are the codes it's throwing:
P0300 Engine Misfire Detected
P1171 Fuel System Lean During Acceleration
P0420 TWC System Low Efficiency Bank 1
P0400 EGR System
I checked the Air/Fuel ratio guage and it never moved from 12.1:1.
I replaced the fuel filter about 8 months ago but im going to replace it tomorrow anyways just to make sure. Any other ideas? I really need to get my car running ASAP. Does anyone know which guage to use on Autotap to monitor the fuel pressure? Any suggestions or ideas are greatly appreciated.
Old Feb 12, 2003 | 05:43 PM
EddyZ28's Avatar
Default Re: Car won't start, need help diagnosing the problem.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by OC BLACKZ28:
<strong> I had the same problem a while back and it wa my k&n filter, it was so dirty that it choked the car. Also, take a look at your throttle body, I found oil in mine from the pcv system. Were you working on the car before this happened or recently? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I cleaned my K&N Filter about 6 months ago, but I'll remove it and crank it to see if it stays on.
I haven't checked the throttle body for oil, so im going to do that next. At this point, the car won't stay on for more than 5 seconds. Ive been trying to check the fuel pressure but I can't get the car to stay on long enough. I might be in trouble.
Old Feb 13, 2003 | 12:50 AM
OC BLACKZ28's Avatar
Old Feb 13, 2003 | 10:54 AM
EddyZ28's Avatar
It looks like I found the problem. I hooked up a fuel pressure guage to the fuel rail yesterday and I got 15psi at idle. I gave it some throttle and the most I got out of it was 18psi. I'm going to change the fuel pump this weekend, hopefully that will solve my problems.
Old Feb 14, 2003 | 12:20 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yeah it should be 57-59psi.
Old Feb 14, 2003 | 12:23 AM
Hp Joe's Avatar
CHECK YOUR MASS AIR FLOW SENSOR AND OR YOUR THROTTLE BODY
