Need Help Asap....
Old Jun 1, 2006 | 11:47 AM
TNTramair's Avatar
Default Need Help Asap....
getting chirping sounds from engine area...what typically goes bad on the pully system that i should look for??
leavin for the Power Tour tommorrow and this crap just came up.
thanx
Old Jun 1, 2006 | 01:01 PM
ski23's Avatar
how do the belts look? maybe tensioner is shot
Old Jun 1, 2006 | 02:55 PM
LoudmouthLT1's Avatar
First thing to look at are the belts. If the belts check out just start the car up and watch all the pullies, see if one is moving at all, if not just find which one is making noise and hit it with some WD-40.
Old Jun 1, 2006 | 03:18 PM
TNTramair's Avatar
problem solved....thanks all.
had a small coolant leak that poped up after a cam install. was leaking right on top of the a/c belt and only while the car was running. fixed the leak..noise is gone.
